Hi all,
How can we record sound (only) without facing the 1 mins restriction?
Thanks ...........
Hi all,
Thanks ...........
Try to record using the Windows Sound Recorder then transfer the recorded sound file to your phone.
Is there any way we can record on our mobile phone without the 1 minute restriction?
Nancy recorder
HipCam!!
Trial at adressremoved
[quote="ivomir"]Nancy recorder[/quote]
Hi r u refeering to pocket nancy?It record both video n sounds.Is there any apps that can record sound only without the 1 min restriction?Where can i find nancy recorder if u r not referring to pocket nancy?
doesnt the firmware upgrade remove those restrictions?
