Synoload: Synology Download Redirector for Nokia 5800
1 replies · 7,889 views · Started 12 May 2010
Hi all,
I've developped a Symbian Series 60 5th edition application able to connect to your Synology NAS and manage your downloads. It is called "SynoLoad" and can be found here:
http://store.ovi.com/content/32552
SynoLoad allows you to connect to your Download Station and manage your downloads. You will be able to add or remove files, but also check the speed or pause downloads.
The smart search engines will allow you to look for any kind of file. New search engines can be added dynamically, so you will never miss your good old finder. Mininova is included by default!
Morever, the built-in RSS reader helps you keep track of your software updates. You will be able to add new RSS feeds to SynoLoad and be notified of new files to download.
Afraid to open your Download Station access to the Internet? SynoLoad handles both HTTP and HTTPS, so it is completely secure!
A complete description is available on my website as well as screen captures:
http://dev.patey.net/synoload.html
A similar application, which is able to connect to QNAP NAS (instead of Synology's) is currently in beta test (on my website: http://dev.patey.net/qgetmobile.html)...
Tell me what you think about it !
Thanks a lot,
Jerome
Hi again,
Just to let you know that SynoLoad is also compatible with other Symbian phones, not just the 5800 !
Regards,
J�r�me
