Bluethooth with 3com BT Card does not work
2 replies · 2,024 views · Started 21 March 2003
Did anyone succeed in connecting the PC to the P800 using the serial port and a 3com BT card?
I get the errormessage "someone else uses the port".
I'm sure, there is not Prog on the PC using the port!
Hello,
You have to set the com ports for both server and client in the phone connecton software, before you start the Bluetooth Connection Manager.
The end of this post pointed me in the right direction, now it works (almoste every time...):
http://www.esato.com/board/viewtopic.php?topic=6662&forum=18
/P
I had a difficult time getting it to work initially but follow the intructions given and you'll get it to work.
