hey
I was just wondering does anyone know how to setup there wifi samsung i8910 omnia HD to there wireless router on the phone so its always connected to the wireless router i have seem to have to connect each time i want to use the internet is there a way that it can be connected to the wireless router always without always connecting each time.
Thanks.
Well, this must be one of the longest waits for a (volunteered) reply!
I strongly recommend you to read up, research about, and decide if you should use an HX ROM (and then, if you do, donate to those guys). I used HX v4 for sometime, then HX v7 now for a month. It is great. I do not recommend using the i8910 for business - buy another device. In my individual case, I gave up with the i8910 for business within a couple of months and never really used it 100% for that purpose, and never changed my mind on that (crashing, and new ROMs = security unknowns).
for anyone else reading this post and just wants a quick try at a fix - go into the i8910's main settings page, and put in your WiFi router's settings there, rather than 'on the fly' whenever a dialog pops up. By 'forcing in' the WiFi hotspot parameters (e.g. WPA2 key) in the main settings, then your i8910 (should!) remember them.🙄
