Hi all,
I'm going to be selling my N82 and I want to clear all my user data out of the phone, but I want to keep the firmware and the basic programs that came with the phone. Should I be doing a hard reset or a soft reset? I read a few different options in a thread about the N81, will all these steps work on the N82?
Here's the thread I'm referring to: http://www.allaboutsymbian.com/forum//forum/thread/80320/
Thanks for all your help!
Do a hard reset or even better a Vulcan Death Grip . See my post here :
http://www.allaboutsymbian.com/forum//forum/thread/81021/
Default Nokia securitty code : 12345
Format memorycard : Menu > ... > Memorycard > Options > Format .
Now your phone is shop clean .
Good luck selling !
😊 Regards jApi NL
Thanks, I'll give it a shot tonight.
I did change the product code (or something) before using NSS, so that I could get the firmware update. Do you know if any of that information will change?
The firmware or ROM wouldn't change by hard reset .
To avoid future problems , inform the new owner . So he will be a happy user , as otherwise there could be confusion because of the difference between the actual firmware productcode and the productcode on the label underneath the battery .
😊 Regards jApi NL
Each time a description of the change, there is always plenty to talk about around the world. They are not exempt. A statement usually is: "i have to change almost immediately versions, so do not expect me to date continue to attack ...
andytseng wrote:Hi all,I'm going to be selling my N82 and I want to clear all my user data out of the phone, but I want to keep the firmware and the basic programs that came with the phone. Should I be doing a hard reset or a soft reset? I read a few different options in a thread about the N81, will all these steps work on the N82?
i didnt go through all those steps. i want to keep my firmware too as i supposed to format my all memory. if i would get anything to do about then i have to read out whole threads. same advice for you. :icon14:
