Msn messenger
31 replies · 6,084 views · Started 21 March 2003
TipicMe can be found here: http://www.allaboutsymbian.com/software/directory/viewsoft.php?id=335
On the homepage you'll have a couple of download options. Download the midp for other devices.
Get the midp runtime from forum.nokia.com
And have some fun 😉
I needed both but some can do only with the jar file ...
It wasn't intended for the 9210 so it has some strange behaviour but it works 100% 😊
and it's free 😉
download them both place them in the same dir, try opening the jar file, and don't give up if it doesn't work 😃 try again, with jad file or something ...
can anyone help me?! Once i have installed hte MIDP runtime and try to run the *.jar file i just get 'Invalid File'!! Does anoyne know the cause or a workaround?? 😞
deary me, i must be thick, lol, on their website i can only see one d/l page for TipicME. I d/l the JAR file for MIDP devices and copy it onto my phone. I then try to run it and an Application named 'Applications' comes up and now says 'Invalid'. I must be doing somthing wrong, can anyone please give me a babys guide of how to make it work?? lol
Thanks 😊
ah yes almost forgot to post them 😛
just use these 2 files, start one of them.
Midp will ask to install ... when it prompts that the jad isn't the same as the jar just press continue.
After install delete the 2 files.
enjoy
wow!! THANKS DAZ!! I dont know what else to say, lol, i have been trying for ages to get this thing to work and couldnt and now I can get it going its BRILL!! THANKS AGAIN!! 😃 😃 😃 :multi:
-Wills
say hi to the newest thickest member of the forum 😊
but i too am getting the "Note :invalid" error when trying to install the .jar on the Applications, er, application 😊
i'd as thick as tapioca pudding and can't figure this out 😞
Dazler said he posted 2 files to help but i can't find em 😞
anyhelp would get a huge kiss from me 😊
look at the last post on the first page of this thread, they are there in a ZIP file. Make sure you are logged in otherwise you will not see the file for d/l.
-Wills 😊
[quote="hef"](bit crap to use though :-? )
still can't complain![/quote]
nope, it isnt crap to use, you just gotta get used to the way it works on the 9210. If you would like to design and program a better version id love to see it, lol :P😃😉
-Wills
okay so cos i can't program like microsoft can i'm not allowed to complain about Windows?
cos i can't make a phone like nokia can i can't complain about my 9210?
and cos i can't program for a 9210 i'm not allowed to have a little nag about a program for it!? :roll:
It's called feedback dude, and without it programs would not get updated and developers wouldn't better their programs and stuff.
Ooooooooook after much fiddling TipicMe finally installed,but i cant seem to connect!I already have a jabber account but it wouldnt let me log on at all!It doesnt get past 0%!
Sooo i downloaded ver 1.3 but this one requires GPRS :evil:
Any ideas guys on how i can get 1.1 to work?
