Hi 6 months ago i got an N95, bought it used at the time aside from a scratch it worked fine without any hinches, but about 2 weeks ago the screen started showing some white lines, and then after 2 days i got only a white screen...
All my reading said that this should be over with a reset i tried that method of *+green key+3 while powering up, stayed a minute like this the screen didn't show any change it stayed white throught the whole minute, i can insert the pin, or at least i think because of the sounds...
Also i've disassembled it and assemble it again (without any leftover pieces) to check the internal cables but none were loose, also tried a repair LCD i bought on a site, but it seems it must be for another N95 version because it doens't even show the white the other one does...
Well my question is do you have any idea what to do?
