which is the best video Recorder for the 7650??
which records longer videos and good quality too
Best VideoRecorder??
HI!...
HIPCAM is the answer... good quality with audio and you assign
the large of the file you want to record...
And you can play the files on a PC with Nokia Media Player or on the
phone with Nokia Video Recorder...
the files are standard .3gp
If you don't want to record large files but only small ones (10 seconds with
audio) i recomend you to use the Nokia Video Recorder alone.
cya! 😃
Yep - he's right, I'll agree with that - Hipcam is great for longer cips - and you can control resoultion and quality too!
Just remember you can not MMS long files, so just think about what you are going to do with the video first and select the right program!
Best 😊
Will
yes I liked hipcam but when Ive rocorded the videos and then it opens Videomms to play them but for few seconds the screen goes all weird like dots and stuff i see in the video like really bad quality but it happens for few seconds in the videos??
has that happened to u guys
or will it work find with the nokia video recorder?
Hipcam is good but sucks at same time. lmao
I tried Hipcam and then play the videos in the nokia videorecorder and it works great 😃 I can now have videos longer then 1 min on my phone
hipcam is a great program.....
I think that Hantro 3.4 is the best videorecorder.
HipCap (trial) had some strangely colored pixels, and other problems with quality.
How Long does Hantro 3.4 record a video?
[quote="Marius"]How Long does Hantro 3.4 record a video?[/quote]
95kb, around 10 seconds.
Go try it yourself, download it from Nokia.com
recording more than 100 kb option places hipcam one step further
The newer official Nokia 7650 video software (or Hantro 3.4 as we know it !) may only do shorter clips but it's far better quality and seems to keep up with fast movement pretty well.
I tried HipCam after people had praised it but apart from the longer recording time the quality was awful - jerky and bitty.
If only they could combine the engine from Hantro with the options of HipCam - THEN we'd have a winner !!
Carpathian
[quote="carpathian"]The newer official Nokia 7650 video software (or Hantro 3.4 as we know it !) may only do shorter clips but it's far better quality and seems to keep up with fast movement pretty well.
Carpathian[/quote]
I agree Come'on Nokia.
PS whilst you're at it. How about BT audio and extra memory for 7650 😃
[quote="Doc"]
PS whilst you're at it. How about BT audio and extra memory for 7650 😃[/quote]
dont make guys stressed 😊
HEY GUYS WE ONLY NEED EXTRA MEMORY! HELLOO??
