Does anybody know if it is possible to make a Nokia SU-8W Bluetooth Keyboard work with a Sony Satio? I've tried the Nokia software and I get a certificate error. In theory it should be possible...:con?
Satio and Nokia SU-8W Keyboard
Festiniog wrote:Does anybody know if it is possible to make a Nokia SU-8W Bluetooth Keyboard work with a Sony Satio? I've tried the Nokia software and I get a certificate error. In theory it should be possible...:con?
try this driver .. for the iGo Stowaway ..
http://corporate.igo.com/support/Dow...20OS9%20En.zip
After installation the Stwy should appear in Applications .. open it and enable BT .. then put the keyboard in discovery mode .. Ctrl and both Fn buttons .. stick in a pass-code on the phone .. type the same code on the keyboard and blue Fn + enter .. you should see it happily spring to life!
Good luck ..
seki wrote:try this driver .. for the iGo Stowaway ..http://corporate.igo.com/support/Dow...20OS9%20En.zip
Good luck ..
Hi seki: Thank you for the tip, but the link seems to have been changed recently and doesn't work for me. I had a look around the iGo site but couldn't find a driver that worked. I guess it was just a step too far...
I have the same problem, i still can't find any app to make the keyboard work... please let me know if you solve this please
