Standby mode bug?
7 replies · 2,699 views · Started 22 March 2003
Anyone notice this....
In Tools>Settings>Phone>Standby mode>Right Selection key...
I selected Video Recorder as the Right Selection Key
While phone is in standby, I pressed Video Recorder (the right soft key which I customized) but it didn't launch the Video Recorder 😞 it opened the Sound Recorder instead of the Video Recorder :-?
Is it my phone only ...
Is it because I've installed Hantro 3.4?
Is it because I've installed Hipcam?
----help---me----pls---- 😉
I've tried customizing my right selection key to video recorder as you've said... It also launched the sound recorder instead of the video recorder. So, it's not your phone only! hehe 😊
Hmm - on my 1.34 os I do not have 'video recorder' just 'recorder' which is the sound recorder.
Looks like someone put the wrong lablel on it 😉
But I do have 'video player' but when I select this I get 'system error'
whenever I try to select it from the soft key.
Oh well - on for Nokia t put on the 'fix list'
Will
Same problem here, i have v2.50. It also opened the sound rec. But the phone is soooo cool, i dont worry about that :P
Hooray! I'm not alone 😃
Thanks mates for trying to check it on your phone ~blushed~
the bug :-? is not a big deal but its still a bug that they need to fix
Thanks again :angel:
how will they go about doinf tht and if they got a new firmware out how would i get it cos i dont have a NOKIA store here?
No Nokia Center in your place... How about asking the vendor where you purchased the device? They should do the free firmware upgrade for your device because of its 1 year warranty
:angel:
