I tried to install it and i am having this message!!Why???...its the Voll version.thanks
Mp3go Incompatible with phone.
Nope it is not incompatible. It is compatible 😊
I've installed the trial version last week and it was installed in the MMC but I removed it coz I dont like it.
Maybe the "incompatible" that you are saying is when you are installing the MP3 go, you seen this: "...not compatible with your phone. Quit installation?" then you have the option to press yes or no. If this is the one you are referring, you just press "No" so that the installation will continue.
