deleting a folder on nokia 5233
7 replies · 11,727 views · Started 03 June 2010
i installed drjukka's application yexplorer on my nokia 5233.the application created a folder in my main menu view.i have attached the photo here.pls help me to remove this folder.
Attachments: Scr000002.jpg
Third party menu folders can be deleted like : Highlight the folder > Options > Delete . Or on some phones use backspace button .
There is only one caveat : the folder should contain no apps . In case there are , first remove them to another folder .
😊 Regards jApi NL
thanks for the help.but on highighting the folder it doesn't shows the delete option.and my phone is touchscreen so it doesnt has a backspace button.so pls tell me any other method.
jApi NL wrote:Third party menu folders can be deleted like : Highlight the folder > Options > Delete . Or on some phones use backspace button .
😊 Regards jApi NL
When you click the Dr Jukka Folder , is it empty ?? Or does it still contain the Y-Browser ?
The Y-Browser should be moved first to another Folder , like "Main Menu" or "Installations" . I see in the screenshot there is some application running in the "installations" Folder .
When you cannot delete the Dr Jukka Folder , use it for new apps you are going to install anyway in the future .
Renaming the Dr Jukka folder shouldn't be a problem . Give it a name like you want . Some name suggestions : Unused , New Apps , Tools , etc , etc .
Hope this helps ....
😊 Regards jApi NL
I myself got the same problem dear today
I Choose 'Options', then 'organize' then select the folder, then select the 'option', there I found the Delete option.....
It worked for me on 5233. Try it! Hope it would help u
Stay Well, 😊
OMAR
omar,
Boss, your trick of deleting folders is the best..good thinking and keep up the good work..
thanks
Parish😃
