I've got a 5 month old N86 and the USB connector has broken, leaving me unable to charge the phone or back it up before sending it off for repair. Most frustrating.
The connector is physically loose, I can feel it 'wobble' when I plug the cable in.
I seems as if the mounting to the circuit board has failed, although I've not had the unit apart to check this, but it seems the most likely cause.
I've read several posts on Nokia's discussion board of others that have the same problem, but Nokia seem quiet on the issue!
I'd like to know if others here have had the same problem, and if so was the phone repaired under warranty?
Thanks,
Keef.
