Hey all,
I just got an E71. Its a really nice handset. However, the in call volume is REALLY low. Its even worse with the earpiece. I have adjusted the volume all the way up with the up/down buttons. I work around servers, routers, and switches and the fans are really loud.
On my moto i had a program to adjust the gain tables of the phone. Not sure if nokia has something similar.
Thanks everyone!!
Do you mean the talk or alarm (ringing) volume ? The ringing volume can be set in : Menu > Tools > Settings > General > Personally > Sounds/Tones . Choose a loud ringing tone like Nostalgia . Set volume to maximum . Also vibration can be set here .
About "Talking volume" : while answering a call , you can choose manually loudspeaker instead of earpiece . When loudspeaker is on , with D-Pad right-left you can adjust volume .
Hope this helps ...
😊 Regards jApi NL
i meant the talking volume. especially with the headset. i use that thing religiously. the ringing volume is fine. Thanks again.
jApi NL wrote:This is what I found about volume boosting : -- AAS How to: Pump up the volume - louder music in S60 3rd
http://www.allaboutsymbian.com/features/item/How_to_Pump_up_the_volume-louder_music_in_S60_3rd_Edition.php
-- N73 ME low volume fix? - AAS
http://www.allaboutsymbian.com/forum//forum/thread/61852/
😊 Regards jApi NL
i guess the equalizer thing helped a bit. Im not real crazy about the speakerphone thing but i guess if i get in a bind i can do that. lol....i cant believe theres no tweaks or anything for this phone.
Thanks again!
Tried using this earpiece again last night. Its just SO annoying that you cant hear the other party unless you lock yourself in a quiet room.
Anyone else have any suggestions?
When you are in a medium loud space , you should be able to make that call ! There could be some reasons for the incovenience :
1) Broken E71 , e.g. speaker
2) it is NOT a real E71
3) upcoming deafness ?
Hope the last one is not true .
😊 Regards jApi NL
