FLashlight app
4 replies · 10,857 views · Started 08 June 2010
Google for S60SpotOn.
I actually prefer using the screen instead of the LED flash light.
On my E71 the backlight is actually brighter than the LED flash.
Outbank.de pulled S60SpotOn from their website . Now all apps they provide is just iPhone .....
But their might be a Torch app in the OVI store .... ?
😊 Regards jApi NL
Application flashlight is a good application. I think that changing the system configuration is a violation of the terms of the SDK. This is probably why it was removed. While this app has brightness controls are an unnecessary - because only reduce the brightness of all the times when you have it. So if you have 50%, will remain in this way, when you open the application.
the E72 has the feauture to use the camera light with one click works fantastic. But sorry I am not of help you got the e71 and I don t know apps that can work that way
