Hi, I have a problam and I hope you can help me.
I'm trying to transfer an iso file 4.7 gb large to my N97. But everytime I try to copy, the phone tells me there is not enough memory. I have 28 gb free on drive E: and 7 gb free on my memory card. both give the same message.
If I try to connect the memory card directly, it works.
If I try to transfer a file about the same size that is not .iso, it works.
If I try to connect the phone and select pc suite it says "the phone denied the action" or something similar.
What can I do?
e369258147 wrote:Hi, I have a problam and I hope you can help me.I'm trying to transfer an iso file 4.7 gb large to my N97. But everytime I try to copy, the phone tells me there is not enough memory. I have 28 gb free on drive E: and 7 gb free on my memory card. both give the same message.
What can I do?
You say "transfer a file about the same size that is not .iso, it works"
.... try renaming the .iso to the same file extension that worked (e.g. zip) - and then rename it back to the original one on the phone.
I tried. It doesn't work. I tried to burn it to an image file with nero (.nrg), tried compressing it with winrar, tried to rename it manually to a rar file... nothing works. It's like as long as the original is an iso, it won't let me do anything.
Does anyone else has a similar problam?
How are you connecting the N97 to the PC? Mass Storage mode, or, PC Suite Mode.
I've just done some testing on my N97 and the W7-64 iso.
Running in Windows7-64, connected via OVI / PC-Suite, the ISO would not copy. Fails with a "not authorised" message.
Running in Windows7-64 connected via "mass storage mode", ISO copies fine.
Target was internal 32Gb storage.
Instead of PC Suite mode, try Mass Storage mode.
This has nothing to do with your available memory, nor naming, nor connection type.
The file system on your mobile and your memory card is FAT32. This type of file system can only hold files up to 4Gb in size. Therefore, it is not possible to put a 4.7Gb (single) file on this type of file system. If you want to transport a file larger than 4Gb using your phone, you would have to split the file in chunks smaller than 4Gb each. This can be done with tools like WinRAR.
