Turn on/off your Bluetooth in just one press
2 replies · 6,432 views · Started 16 June 2010
When I had an N95 I had an app called BTSwitch that would turn my bluetooth on and off by just opening it. I've missed it when I moved to the N97 because I didn't think it would work on S60 5th edition...
But now I've found it again!! A copy that works on 5th edition!
I haven't seen it in the N97 forums so I thought I'd share it with you all now. You need to sign it though, but if you use your bluetooth a lot then a little time spent signing the app will save you a lot more time in the long run.
I hope this helps anyone!
Attachments: BTSwitch_v1.00_unsigned.sis (11 KB)
Nice one zxon!
I have Bluetooth switch on my N95 and missed it on the N97, having to make-do with one of the home screen shortcut icons dedicated to Bluetooth.
Now I have the SPB Shell installed I can use the Bluetooth switch feature on that.
ironass wrote:Now I have the SPB Shell installed I can use the Bluetooth switch feature on that.
Yeah I like that option in SPB Shell too, however after having had to change the time on the phone I lost the use of it (Fixed now with the beta install). It's nice to have a little app like BTSwitch around anyway, just in case 😊
