which phone is better?
Nokia E52 or Nokia E75?
in terms of:
1. hardware
2. software
3. firmware
4. applications
5. overall performance
PLEASE HELP ME CHOOSE A PHONE 😊
THANKS!!
in terms of:
1. hardware
2. software
3. firmware
4. applications
THANKS!!
Just out of curiousity, why are you not considering an E72?
nottmbantam wrote:Just out of curiousity, why are you not considering an E72?
i'm not considering it because of it's size. 😊 please help me choose between the two. i'm really confused. :con? thanks!
I use an E72 so don't have working knowledge of the other two phones, but AFAIK they are built on the same OS and platform so should be pretty much identical in terms of software and available apps.
If I had to choose between them, I would go for the E75 mainly cos I like the slide out Qwerty kb, which by all accounts is very nice to use. Other than that, I don't think there is much to choose between the two.
hmm, i'm really confused about the two. which one is better. having their own latest firmware updates, w/c one is greater now? thanks alot.
E75
