Bluetooth software suite
6 replies · 6,097 views · Started 22 March 2003
When i install modem setup on my pc i need bluetooth software suite to install a modem over bluetooth.Where can i get the bluetooth software suite? Thanks in advance.
Bluetooth drivers are already installled.I can use pc suite and remote60 but i want to use phone as modem for laptop.The modem setup for nokia 7650 only gives me the option of installing an infrared modem.The bluetooth modem option is not highlighted and says this "to use a Bluetooth connection you must have the nokia connectivity case dtl-4 or other bluetooth v1.1 compatible card or device;and you must have installed the Bluetooth Softwar Suite on your pc" all help appreciated.
Sorry, I forgot that you dont have to install that Modem software at all,
If you have the modem option in the BT software, use it. It should work.
:x Bluetooth drivers are already installled.I can use pc suite and remote60 but i want to use phone as modem for laptop.The modem setup for nokia 7650 only gives me the option of installing an infrared modem.The bluetooth modem option is not highlighted and says this "to use a Bluetooth connection you must have the nokia connectivity case dtl-4 or other bluetooth v1.1 compatible card or device;and you must have installed the Bluetooth Softwar Suite on your pc" all help appreciated.
[quote="wannyondeathrow"]When i install modem setup on my pc i need bluetooth software suite to install a modem over bluetooth.Where can i get the bluetooth software suite? Thanks in advance.[/quote]
You do not need pcsuite or mrouter to use your cellphone as a modem.
If you have installed your BT Software it automatically creates a serial client, DUN Client, Fax Client etc.
To use 7650 as modem do the following. (Instructions given are for win 98)
Go to my computer - Dial up networking. If you have available dial up connection (one used for pc modem) right click and open properties.
Go to connect using and select Bluetooth DUN Client.
If you don't have available dialup connection? Create one and select Modem as BT DUN client.
Now go to nokia and enable BT
Important Mrouter must not be running (Remove PC Suite from Startup and reboot)
Run BT software and make sure connection with phone is established.
Now go to my computer - Dial up connection - Double click your internet connection. Enter user name and password and press connect.
Nokia will ask if you want to accept connection from PC. Click yes and your connection should start.
