Hey Iron, I hadn't seen the one about it smashing, I watched the will it blend and it looks like a tough little phone to break down, goes pinging around all over the place!
Stuntman wrote:I don't doubt that the resolution is great and the images on the iPhone 4 are crisper than on the N97. The specs sure are impressive. I'm just wondering if you had a chance to compare the iPhone 4 display to the N8, Nexus One or other phones with similar displays. I would like to know how the iPhone 4 display compares to other high end phones that came out around the same time.
My brother has the Nexus One, it's a nice AMOLED, but for viewing angles the iPhone rocks, it's the same IPS screen that's on the iPad which means you can basically view it from any angle. It's pretty intense!
The width of the phone is just crazy too, i feel like i drop it each time because theres so little to put down and it's very flat.
A new note on charging, battery was at 52% and within 29 minutes it's up to 80% (using my mains powered iPad adapter. Yes, i'm sorry, i have an iPad too, i still hate apple, would love to see a USB or you know some .avis, but they're design and implementation stands far above others in my eyes)
Had a fairly long facetime chat, I have used 3g video calling before, but facetime, is way better. Clearer, louder, almost no image blur and higher res, but then it is wi-fi only, but that also means its free!
Stuntman wrote:Also, have you experienced the yellow streaks that have been reported by some iPhone users?
Nope, though i read on Engadget somewhere that the yellow dots are part of the bonding process and that they're only there because the factory is shipping them out too quick, but after a few days use with the screen on, they'll evaporate. the guy who said works for the actual glue company so i think it's fairly reliable!
On the antenna note, i tried it and really squeezed that bottom corner where the antennas met, my signal started to drop like you can see in the YouTube vids, but after it went down to 2 bars, it went back to 3 and stayed there while i made a minute long call which sounded fine, so not sure about that one, i'll see if it happens in the future, could be annoying.
Stuntman wrote:Nokia is moving to MeeGo for high end phones in the future. Sounds like they are following WinMo in that sense. My understanding is that WinMo7 is going to be totally different than older versions. It's almost like going from Symbian to MeeGo.
One last thing. I was wondering if you considered any other device when you decided to upgrade from your N97. If so, what was it about the iPhone that made you go with it over other smartphones.
WinMo7 just looks really different and i do miss widgets on my home screen (calendar) the most, but now i have the calendar on My Yahoo! page and it syncs automatically to the phone too, so i don't miss any events.
I was considering the HTC Evo (on android) the N8 and the iPhone 4. I ruled the N8 out when i saw the low processor speed, ram and Symbian on it, it would be the N97 waiting for updates again. Too much time i spent on that phone! The Evo I ruled out because i'm not even sure it's coming over here, it definitely wont be 3G.
And from my bro, who bought the nexus one a week after launch and has just ditched it for the iPhone 4 told me that Android just isn't as polished and although Apple has strict rules (far too draconian and i do hate them for it a bit) for it's apps, that's what makes them so good! so polished and easy to use. Everything just works, almost right away and you don't have to worry.
Apple is like Mussolinis (sp) Italy, it's harsh sometimes, but all the trains run on time!
I spent about 4 seconds taking a picture with the geotagging turned on, processed the pic in less then a second, went to "places" and there it was already on the map!
Downfalls of the iPhone 4? Cost. And don't forget about the cost of accessories, Apple want �25 for a dock, it doesn't even come with the USB cable, it's just a heavy piece of white plastic with a 20 pin connector. for TWENTY FIVE POUNDS! Chargers are like �20, who doesn't have 5 Nokia chargers lying around or buy one for 99p!
No simple micro USB. May take a little while for Longtime Nokia users to get used to it all, well it is for me!
Hope i helped a little!
