Hi All
Does anyone know of any utility/programme that allows you to export/import all of the fields used by the 9210 contacts database as a simple Comma delimited file.
Many TIA
John Walker
Hi All
Many TIA
John Walker
I know that smallbase (from version 4) will import the contacts database (copy it to your card first).
You could import it into that and then export it as a different format?
Thanks for that.
I was actually wondering (as I was searching the web for a solution to my original question) whether Smallbase or Powerdata were better answers to the whole Contacts thing (which I really find very restrictive and not anywhere near as flexible/fast as it was on my old Psion).
Am I correct, in assuming that if you set up a database the way you want it in Smallbase, you would not have full interaction with the phone, fax & email facilities on the 9210?
Or... is it possible, for instance, to get the phone to use the Smallbase data as the current Contacts application does - particularly as a phone number database when the communicator is closed?
Many TIA
John Walker
