Video conversion to MMS
0 replies · 4,772 views · Started 30 June 2010
As an ex N95 user I used to record my videos in the highest possible resolution. I If I ever had the need to convert and send one the N95 had a built in video editor and converter to resize the file to an appropriate MMS size. I cannot seem to find the same feature in the X6, not sure if I am being thick or if it is just not there, I can find the editor to cut and merge but it does not have the same MMS feature as the N95
