Browsing w/ Opera via Bluetooth..., How???
11 replies · 3,048 views · Started 23 March 2003
Anyone knows how to browse with opera via bluetooth?
I can connect my P800 with Opera browser to my ADSL connection via the cardle..! But, how do I setup the connection via bluetooth???
Thanks in advance
I read that thread already...
I'm sorry I didnt explain the details...., Actually everytime I'm going to open an homepage.., the Opera always ask which connection, and it doesn't have bluetooth options in it... regardless I already established my bluetooth connection with my computer...!!!
What should I do now???
Maybe you should try reinstalling Opera. As long as you have internet connection on our pc and Bluetooth is Connected and not only enabled then you should not have any problems at all. TO check whether BT is really connected to PC try syncronizing your P800 with your PC.
raven..suggest my thread. no offense.. but its easier than the one you suggested...
here you go bbezaita
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=7855&highlight=blue+tooth+solution
Your topic and mine is not about the same thing though. Yours is about establishing a BT serial port connection, while mine is about using this connection to browse the web on a P800. The difference is that my topic is for ppl who's already familiar with BT, at least enough to make a BT serial port connection... taking it a step further. So I guess your topic would be good for starters, and then taking a look at mine for using this connection to browse through your computers gateway. And as far as I can see that was actually what the thread starter asked about when I replied... no offence..
raven, ooh none taken !
Its just that once you have established a connection.. tis obvious how to surf :\ via BT... i mentioned that...
😊 good job
It's not obvious to all. Many ppl don't that it's possible. Is it obvious how to use BT/DSL to send/receive e-mail on a P800? Is it obvious how to use this connection with the built-in browser?
I tried to connect w/ the BT Serial Port device, but every times I press except, my PC always say "The Bluetooth Serial Port connection failed. The remote device closed the connection."
Anyone know how to work this out?? please help
Did you pair your p800 to the PC? I would suggest starting the serial port connection by unchecking/checking the com ports in mRouter(double click the little icon in your taskbar that looks like two small arrows pointing in opposite directions). Just try checking them all and uncheck/check them one by one to find out which com port uses the serial port connection. After a little while one of this com ports should say connecting and then connected, and a little blue p800 icon should then appear in your task bar. Then you should see on your p800 two small arrows pointing in opposite directions next to your BT icon on the bottom of the screen meaning you are indeed sucsessfully connected. And now just open opera on your phone and it will choose this BT connection over GPRS.
[quote="CorruptedSanity"]raven..suggest my thread. no offense.. but its easier than the one you suggested...
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=7855&highlight=blue+tooth+solution[/quote]
Thanks for the link...., yaayyy finally... it's working now 😃
Thanks guys...! :angel:
