please help me with these simple probs
2 replies · 1,634 views · Started 23 March 2003
ive set bemused up and everthing seems to be working i can see all my music on my phone and winamp appers on my pc but i just cant play any of the tunes any one have any ideas
and second when using pc file manager if i wanted to place files on my phone where do u put them ps it is programs and games i wanna put on there i know there are other ways to do it but i really wana know this way
cheers again
If it's a .sis file simply make sure you have a connection in mRouter and just double click the .sis file - it'll look like it's installing on your PC, but in fact it's installing it into your phone!
Java apps you need to send to your phone first
Just right click the file then click 'send to', 'bluetooth', your phone.
You don't even need mRouter connected for this to work.
It will send the file to your inbox on your phone, from there you can install it.
Never used bemused - is it any good?
Best 😊
Will.
I already did the hard reset but didn't work...the thing is i don't know if the service center can still install the system files...since i cannot even access the main menu for activating infrared device to access my laptop files...i last installed the wildskinz software...I think it did the damage...thanks anyway...should i buy a new mobile????or there is a chance for my mobile to be saved...
