Since updating to the latest OVI and PC Suite, and applying firmware v22.0.110 I'm benig plagued by "Found New Hardware: MTP Device" notifications.
This is happening after several reboots on three XP machines.
It's probably just me 😞
matthewrleech wrote:Since updating to the latest OVI and PC Suite, and applying firmware v22.0.110 I'm benig plagued by "Found New Hardware: MTP Device" notifications.This is happening after several reboots on three XP machines.
I had the same thing, about 3 versions ago.
In the end, I uninstalled Ovi Suite, PC Suite, Nokia Connectivity Cable Driver, Nokia Multimedia Common Components, PC Connectivity Solution and anything else Nokia.
I then used Nokia PC Suite Cleaner:-
http://europe.nokia.com/support/download-software/pc-suites/how-to/nokia-pc-suite-cleaner
I then reinstalled PC Suite first and connected my N97 with no problem.
I then carried on and re-installed the various component parts of PC Suite (Media Player, NSU, etc,) and then went on to install Ovi Suite.
You can find alternative answers here:-
http://discussions.nokia.co.uk/t5/Connectivity/MTP-device-won-t-install/td-p/568170
Hope this helps! 😃
ironass wrote:I had the same thing, about 3 versions ago.In the end, I uninstalled Ovi Suite, PC Suite, Nokia Connectivity Cable Driver, Nokia Multimedia Common Components, PC Connectivity Solution and anything else Nokia.
Hope this helps! 😃
It's helped me to realise that the notifications are less of a nuisance than I thought :tongue:
