Something strange has been happening to me for a couple of months now.
If I try to update either Ovi suite or PC suite, the update will begin the download and get to 99% and then I get a message telling me that the download failed. Can't remember exact wording.
This happens every time I try.
I manually downloaded the updates last time and then manually installed, but I should be able to update via both suite's.
I run windows 7 64 bit. There is no problem with my internet access.
Anyone any ideas as this is really baffling me.
dog-man
The new updates, ironically, are to fix issues with Windows 7.
Might I suggest following my post here:-
http://www.allaboutsymbian.com/forum//forum/thread/95547/
and then doing a fresh install of the new versions of PC and Ovi Suite.
Hope this helps.
I will have a good look at that, but I do recall when I first had this problem uninstalling and manually installing but still the same.
dog-man
dog-man wrote:I will have a good look at that, but I do recall when I first had this problem uninstalling and manually installing but still the same.dog-man
Did you use Nokia PC Cleaner which gets rid of the "crud"?
No I did not, but will this time! :icon14:
dog-man
