5800 Xpress Landspace Mode Problem
2 replies · 5,382 views · Started 09 July 2010
Hi, for some reason my Nokia 5800 Xpress landscape screen mode has stopped working. This is across all apps and menus where it used to work. The display is working fine in portrait mode but when I tilt the phone on its side it never changes to landscape mode. I have not dropped the phone or anything like that so I have no idea why it would stop working.
Has anyone else found the same problem? And knows how to fix it?
Thanks!
smithy wrote:Hi, for some reason my Nokia 5800 Xpress landscape screen mode has stopped working. This is across all apps and menus where it used to work. The display is working fine in portrait mode but when I tilt the phone on its side it never changes to landscape mode. I have not dropped the phone or anything like that so I have no idea why it would stop working.
Thanks!
Have you checked that System -> Phone -> Sensor settings -> Sensors; is set to "on" and that Turning control is set to "Auto-rotate display"
If that is all set up correctly, I suggest a hard reset and reinstalltion of your software!!
Hope that helps.
