Modem over bluetooth
5 replies · 2,590 views · Started 23 March 2003
I have the wavelinker usb bt runnin the supplied software (blue manager 2.0) and i want to install MODEM SETUP FOR NOKIA 7650 but during the installation i am given no option to install a bt modem.I dont want to use the blue manager software as it is (naff).How do i install the modem setup for a bt modem? Thanks
[quote="wannyondeathrow"]I have the wavelinker usb bt runnin the supplied software (blue manager 2.0) and i want to install MODEM SETUP FOR NOKIA 7650 but during the installation i am given no option to install a bt modem.I dont want to use the blue manager software as it is (naff).How do i install the modem setup for a bt modem? Thanks[/quote]
I've been told by Nokia that the BT modem software from Nokia Suite only works with their PCMIA Card.
But they also told me that this is the only BT that works with Nokia Suite?
Have you got a link where i can download this soft? The bluetooth software suite.Also what is the best software to use with the wavelinker usb bt?
[quote="wannyondeathrow"]Have you got a link where i can download this soft? The bluetooth software suite.Also what is the best software to use with the wavelinker usb bt?[/quote]
The BT software suite are the drivers provided with your BT adaptor. They should be loaded when you install BT Adaptor. Check the web site of your hardware for possible upgrade. The software provided by hardware supplier is generaly the best to use. Sorry I Have no experience with wavelinker usb.
I'm facing the exect same problem, Bluetooth drivers are already installled.I can use pc suite but i want to use phone as modem for laptop.The modem setup for nokia 7650 only gives me the option of installing an infrared modem.The bluetooth modem option is not highlighted and says this "to use a Bluetooth connection you must have the nokia connectivity case dtl-4 or other bluetooth v1.1 compatible card or device;and you must have installed the Bluetooth Softwar Suite on your pc" all help appreciated. :x
[quote="Maverick1"]I'm facing the exect same problem, Bluetooth drivers are already installled.I can use pc suite but i want to use phone as modem for laptop.The modem setup for nokia 7650 only gives me the option of installing an infrared modem.The bluetooth modem option is not highlighted and says this "to use a Bluetooth connection you must have the nokia connectivity case dtl-4 or other bluetooth v1.1 compatible card or device;and you must have installed the Bluetooth Softwar Suite on your pc" all help appreciated. :x[/quote]
Check this link for answer
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=9890
