Where do i put the gb,gbc files, im using PC File manager, i read the instructions is say copy the files to the phone and open it in INBOX, what inbox?
Need Help in GoBoy!
your email inbox
dont use a file manager, send them to your phone over bluetooth or IR and the will be received as a message in your inbox
Tanks a lot man! I be able to send files to my mobile but when i open it it says memury is full try to close some application, so wats next?
check the series 60 gaming section for full instructions. 😊
i even updated the easy to understand instructions for you 8)
here's the direct url;
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?p=70871#70871
