😃 finally i am surfing the net over bluetooth! (posting this on p800 sitting on setee!) thanks for all the help also the solution on essato forums was the one that sorted it for me.
im on a wavelinker bt dongle with tecom software. Now all i need is a way to boost bt signal so i can surf in bed!!
Surfing over bluetooth!
shimmy hill..
welll is ur bed 10 meters away from ur pc? if so.. i have an idea...
usually with bluetooth dongle it comes with a USB extended cable..so get a 5 meter one or aslong as possible and then pull the BT usb adapter as close to ur bed as possible.. or get ur bed closer to ur pc :P
or get one of these...
http://www.bluedsl.net/bluedsl_descript_eng.htm
from here...
http://www.blueunplugged.com/
And have wireless wherever, whatever.
Roll on payday 8)
If only SE or specifically Sony would come out with a WIFI memorystick duo.....that'll rock!!
[quote="Shimmyhill"]😃 finally i am surfing the net over bluetooth! (posting this on p800 sitting on setee!) thanks for all the help also the solution on essato forums was the one that sorted it for me.
im on a wavelinker bt dongle with tecom software. Now all i need is a way to boost bt signal so i can surf in bed!![/quote]
