How Do I Find My Product Code / Maps Question.
2 replies · 9,631 views · Started 17 July 2010
I de-branded the phone ( N95 classic ) about two years ago and have since done several FW udpates, but now , I don't know what the phone's product code is - is there a simple way to check without first connecting to NSU?
Secondly, tried to fire up Nokia Maps but it wouldn't start saying I had to update the application from Nokia Maps. Went online, but all the Ovi maps don't seem to list the N95 ( Classic ) and can't find a version for this phone. Any ideas?
Cheers.
Try to remember your product code ?
You will probably have product code Euro 1 . Maybe 2 or 3 .
For reference :
http://www.allaboutsymbian.com/forum//forum/thread/58225/
You can check the language pack by going to : Tools > Settings > General > Personally > Language . The language pack refers to the product code .
As far as I know on N95 only Nokia Maps 2.0 (with Teleatlas maps) can be used .. Straight download of these maps can be realised by going to
-- symbian underground maps
http://symbian.clanteam.com/indexmaps.htm
-- martin letis: Nokia Maps download links
http://blog.martinletis.com/2008/02/nokia-maps-download-links.html
😊 Regards jApi NL
jApi NL wrote:Try to remember your product code ?
For reference :
😊 Regards jApi NL
yeah, thanks Japi, I debranded more than years. I can't remember what I did this morning, let alone a Product Code from that long ago 😮
Thanks for the tip though, appreciated. Just checked the language packs and it looks like I'm on Euro 1 ( Plum ) Product Code
