Where backups stored on the memory card ?
1 replies · 6,040 views · Started 17 July 2010
After my previous N86 got damaged, I may be going OTT when backing up my new one.
When using the onboard Backup Utility when it saves to the Memory Card, i've search the whole card but I can't find where the file is stored....... plus is is an nbu file that is created like backups that are done via pc suite ???
The backup is stored in a hidden folder , called "Backup" . The file is named Backup.arc .
You can use third party Filemanagers to find them in the device :
X-Plore (eternal free trial) : http://www.lonelycatgames.com/?app=xplore .
Y-Browser : find it in the OVI store .
Or use a cardreader on your PC ...
😊 Regards jApi NL
