Hi folks,
i am thinking about buying the 3650 mobile phone. But i have one question concerning the games. How do i control the games (e.g. Snake) with the 3650 ?? Is it with the 2,4,6,8 keys ?? If so, can anyone tell me if you get used to this kind of control quickly or if it takes a long long long time ???
Thx
You should not forget that Nokia 3650 has also those scroll keys to move around the menus, games or applications....
the movement that can do is:
up,
down,
left,
right,
and middle(for opening windows, applications, shoot on games etc.)
Now it is 24 of March....(it is only one week until "the end of March"😉
i know that the 3650 has these scrollkeys. But i wonder if i could use them for regular games also. I think most games are programmed to be controlled with the number keys. Does the 3650 scroll key also work as a control ? Or do i have to navigate with the number keys in games ??
Hi.
I've not played too many games, but all the ones I have played have always used the scroll key.
All the best games are the ones written in symbian for the 7650/3650 so they will take into account of the scroll key.
But also the Java games I have played make use of this too.
Best 😊
Will.
