The reason Nokia "Flagship" devices are so poor, is easy, and exemplified by the FORTHCOMING N8...
Nokia's "lead in" time, for a new device, from announcement, to retail channel, is so so so slow compared to many other manufacturers, and Android etc.
Why this is the case, when you are wholly in house (OS, materials, design, construction), is well beyond me.
But this invariably always means that a Nokia Flagship device, even if we were to PRETEND that it was bang up to date spec wise, for EVERYTHING, at the time it is announced, is matterless anyway, because by the time it comes to retail, lots of it's features are by then old-hat.
I'm over exaggerating things for sure, but the basic principle is a sound one. Nokia really do have a long lead-in time, from Announcement to Retail.
And linked to this, and the other great issue, Nokia are not ahead of the game.
As a result, theie FORTHCOMING (yes, it's not even out YET), 'flagship device', the Nokia N8, uses a screen resolution lower than any other high end smartphone from any other manufacturer.
@Steve/Rafe.... I know you two SOOOO want the N8 to succeed, and want to give it every change etc.
But I'm serious Steve, if you go with the theme of your "let's spot the key flaws with each previous Nokia high end device", then alas, before it's even out, the N8 does have one.
And there are many that say "so what's the issue with only a 600px wide display...?
Neglecting to realise, that once you hit 800 wide or over, the vast majority of websites, full real websites, provided they are properly coded, will not need any scrolling to display width-wise, as they should reflow or fit for an 800 wide display.
So this makes any screen less than 800 wide, a fundamental issue, as your entire use of that device, for evermore (as it's a hardware feature), will have a restriction, issue, or flaw to it.
So Rafe or Steve, if you do not feel this is fundamental, I cannot comprehend how you think that...
Steve - as someone who appreciates the difference a 2.6" screen on a qwerty Nokia would have made, to a 2.4" one fitted instead even despite what would sound like only a .2 inch increase, then you simply HAVE to understand the fundamental issue of a screen that is not 800px wide, in terms of the issue it will have for evermore, with web-pages, that a 800px+ display device most often won't have.
So Nokia have done it again... and we all know why... expedience. And THAT my friends is the issue with Nokia... too much of what they do is driven by expedience only...
Using 600px displays meant they could just go with what they already had, a la X6 etc.
Great. But how does that make you remain competitive in the high end smartphone field, when other manufacturers have been using 800px+ screens for AGES, and your flagship device ISN'T EVEN OUT YET, and yet will only come with 600px screen.
THESE reasons, the underlying problem with Nokia, are why they are failing dismally, and will continue to do so.
After moving from 67 Nokias, over to Android recently, I would have LOVED for the N8 to be the device that brought me back into the fold. Indeed the camera aspects of it are still trying to tempt me.
But move back to a 600px screen, from my current 800px one...?
How is that a step FORWARD for me?
And that's the problem... if it means a step BACKWARDS for me, then it' means it's a step backwards for NOKIA...
It seems Nokia don't want to learn... but one thing's for sure... if they DO finally "get this", it will certainly be too late by then, as the N8 needed to stem the flow for now, and I'm not sure it will now...
