Nokia 3650 (Bluetooth profiles / USB Adapters)
3 replies · 2,934 views · Started 23 March 2003
Ok this is a tough one.
Been searching the net high and low and not really found the information I need. Maybe I can get it collected in here?
What I lack is the following:
1) What kind of profiles are there in the BT specifications.
2) What do the different profiles do.
3) What profiles apply to the 3650.
4) Which USB BT adapters match the profiles the 3650 has.
5) Which USB BT adapters actually work together with the Nokia 4650
6) The best way to connect the phone to the pc with the USB BT adapters
If you guys could help me out gather a comprehensive list of stuff, I am thinking of doing a website about it.
Let me hear from all of you. 😃
/Tatus
[quote="Tatus"]1) What kind of profiles are there in the BT specifications.
2) What do the different profiles do.[/quote]
Go here:
http://www.informit.com/isapi/product_id~%7B7C5F4B65-5C59-4269-A385-2E2FB42B4C64%7D/content/index.asp
Its 6 pages long article with all current profiles, and a few coming ones.
[quote="Tatus"]3) What profiles apply to the 3650.[/quote]
Generic Access Profile, FAX profile, Dialup Networking Profile, Serial Port Profile, Generic Object Exchange Profile, and many others.
[quote="Tatus"]4) Which USB BT adapters match the profiles the 3650 has.[/quote]
All BT's should have those profiles.
[quote="Tatus"]5) Which USB BT adapters actually work together with the Nokia 4650[/quote]
No idea 😃
[quote="Tatus"]6) The best way to connect the phone to the pc with the USB BT adapters[/quote]
What ??
4)
sitecom (i use it)
acer (a lot of people use them)
msi
all bt adapter can u use. only the software is important.
cya amigappc
No idea 😃 [/quote]
/doh me. I meant for the Nokia 3650
