Connecting 7650 to Bluetake USB Dongle
1 replies · 2,092 views · Started 23 March 2003
Ahhhh!
I just can't get this to work! The Bluetake USB dongle is good (for the price) and works perfectly with my T68i, but I simply can't get it to do anything with the 7650.
I've downloaded the latest version of PC Suite from Nokia, and I think the problem lies with the virtual com port not staying connected properly.
When I create the virtual com port, it immediately disconnects itself.
All I want to do is sync my contacts, but the 7650 also doesn't seem to be able to recieve a batch of business cards sent from either my T68i or frmo my Handspring (Palm OS). Neither can I put them all on a SIM card and copy them all, you have to do it one by one (at least I think you do, can anyone tell me differently?).
If anyone has any ideas, I would love to hear from them, it's really annoying.
Thanks in advance,
Ian
I restarted both the phone and the PC, opened mRouter and clicked a couple of boxes, tried to connect with my Bluetooth software, and everything sprung to life, green/blue things swirling, things flashing.
The sync "worked", screwed my data a little, but sync's alwasys do that!
Phew!
Ian
