N95 call log saving.
1 replies · 7,371 views · Started 02 August 2010
Hi all.....
I'm new here and this is my first post.
I need to know if there's any way I can save the data in my call log. It only holds the records for 30 days and I'd like to save the last 30 days and move it to my pc, as text file or any other format, and proceed with updating the software(which will delete the log).
Any ideas ?
Many thanks in advance.😊
When you install Nokia PC Suite on your PC , you can make a Backup .
Also , when visiting Menu > Tools > MemoryCard > Options > Make Backup/Copy .
After Flashing the new Firmware , restore the desired data via PC Suite , or from the Backup on MemoryCard .
Attention : the MemoryCard Backup does NOT contain the Calendar items !!! For some odd reason . Nokia PC Suite does though .
Just in case you want to be sure , make Screenshots of important data before firmware reflash . Also in future , you could do this every 30 days when needed .
😊 Regards jApi NL
