Hi, my omnia's screen did broke and wited over month new one but now when i have it working again i have forgotten my security code, did flash new firmware but it didn't reset it so what next? don't wanna pay lot's of for some licensed fixer...
Security code help
I see... this one sounds tricky. I might need more information to solve it, as you are a little sparse on detail. It goes against logic - normally a re-flash will remove all user settings... unless you are talking about a PIN on the SIM card, rather than the handset? :con?
Either way, research about it, decide, then go and get the latest HX ROM (and strongly think about donating to those guys), reflash again (you will lose all user data on the handset, all partitions).
Good luck! 😊
