This is fun. Let's do a Nokia reviews vs Android reviews comparison in terms of what is the most important consideration in reviews of both. Though this is intended as a jab at Nokia, there are some surprises there!
1) OS. Nokia: Do the widgets at last work properly on the two year old OS which will never be upgradeable to something better?
Android: When is it getting Android 2.2 and 3.0 (timeline being months not years)
2) Form factor.
Nokia: Oh, space bar, where art thou this time.
Android: Is the default prediction on on-screen keyboard OK or could it use any of the 20 other keyboards available?
3) Memory
Nokia: Can the RAM handle more than 5 apps open?
Android: RAM being always more than 350 MB, ceases to be an issue.
Nokia: What is the internal memory? Can it handle web cache of two browsing sessions?
Android: Oh, it is not sufficient to install more than 50 apps! (though fixed now through ability to install apps to card)
4) Processor:
Nokia: 434 MHz! So much lovelier than mere 400 MHz!
ANdroid: Who even cares? The phone is fast anyway.
5) Interface
Nokia: Three home screens! (oh no, that's Symbian^3). Widgets that work!
Android: More home screens than anyone really needs. Also, widgets that are FUNCTIONAL, INTERACTIVE and JUST WORK with or without constant data connection.
6) Menu structure
Nokia: Oh no, they changed the folders again
Android: All of my apps are on homescreen. What's it like to be in a menu?
7) Usability
Nokia: All menus have kinetic scrolling except contacts. Hope they fix it in a future update
Android: Just put the finger there and flick - is there any other way to scroll?
Nokia: Ovi store is good but only has 5 apps for this model and those too are available between 3 am and 5 am only. Too bad Nokia did not enable more for this particular version of a two year old OS.
Android: Now, would you like an app for that or a custom ROM for that?
Search:
Nokia: Search has improved - now only takes ten seconds. Voice dialing is faster though
Android: Sorry - connect to google first for anything search related. Offline is no go.
Messaging:
Nokia: Look, we have a conversation view!!!! No, not on THIS set, that'll be Symbian ^3, yours for only 500 quid.
Android:
Is there any other way to display messages?
8) Battery life
Nokia: Too bad, doesn't last more than 2 days
Android: Too good, lasts for 6 whole hours!
9) Price
Nokia: Excellent phone for the mass market
Android: Mass market? What's that?
