Possible to make an application shortcut from a web Bookmark?
1 replies · 9,114 views · Started 09 August 2010
THere are two websites I use allot. Obviously they are saved in my bookmarks but what I want to do is have them available as individual shortcuts from the menu screen, so when i access them it will fire up the browser and take me straight to that specific page.
Is this possible?
I know you can make one of the six app shortcuts on the home screen a bookmark or url...but that's not what i want to do.
Had a little play around with this, and could not find any method of moving a Bookmark into the main Menu screen, it seems the only option is to move it another Bookmarks Folder. Other than that, the only option I can think of is what you have already suggested, to have the Bookmark as an Application Shortcut on the Home Screen.
I'm sure you are aware, but I'll mention it anyway, a long press on the number 0 (zero) immediately opens up the browser and takes you straight to the Bookmarks, so if you have the top two used bookmarks at the top of the list, this long press on 0 will take to straight to them, then just select which one you want?
