Problems with multiple e-mail accounts
8 replies · 2,666 views · Started 24 March 2003
Am I the only 1 experiencing this problem?
I have two pop3 e-mail accounts, and they both work perfectly when I try to "get&send" them individually.
BUT: If I want my p800 to automatically check my e-mail accounts using the "schedule" option (control panel -> connections -> messaging accounts -> edit account -> inbox) it doesn't work!!
For some reason, my p800 only wants to automatically check the e-mail account that I edited last - and just ignores the other account's settings!!!?
Both of them are set to use the preferred connection account.
Anybody got a good explanation/solution?
rgds
Carsten
I see that people read my previous post but w/o replying.
Even if some of you outthere can't come up with a solution/answer, maybe some of you can just CONFIRM that you are able to schedule automatic download (having 2 e-mail accounts)???
I would really appreciate it...
Rgds
Contour
i have 3 pops but dont use scheduling until there is a "leave copy on server" in the p800 mailclient.
muh
[quote="muhkuh"]i have 3 pops but dont use scheduling until there is a "leave copy on server" in the p800 mailclient.
muh[/quote]
Yeah, I agree. I can't believe they didn't include this extremely basic option! My old Nokia 9110 has is.
Could I ask you - just for test purposes - to test the schedule function by sending a handful of e-mail to yourself and temporarily activate scheduling?
THAT would be highly appreciated.......
Rgds
Contour
Contour, same here. It won't check all the accounts, only one of them.
I don't allow it to get/send automatically though, as i rely on sms notifications from my service proivder. when i find there is an email that i need to check urgently, then i check the mail. So it might be worth looking into sms services
[quote="Fais"]Contour, same here. It won't check all the accounts, only one of them.
I don't allow it to get/send automatically though, as i rely on sms notifications from my service proivder. when i find there is an email that i need to check urgently, then i check the mail. So it might be worth looking into sms services[/quote]
Thanks a LOT Fais! Nice to get it confirmed. SMS notification is ok but its not what I wanted..
I hope SE will fix what seems to be an obvious bug to me!
SE?
I have 3 pops but dont use scheduling until there is a "leave copy on server" in the p800 mailclient.
muh
The e-mails are always left on the server. They are only removed if you delete the message after downloading. 😃
John.
Contour, I also have the same problem. My work-around is to have my most important account use scheduled downloads and then I manually Get&Send once a day on my other account.
[quote="Contour"]Am I the only 1 experiencing this problem?
Carsten[/quote]
Hi there
Sort of got the same thing.
I have 3 emailaccount configured, one of them should check thrice a day, one of them only once a day and one just on demand. Indeed the last edited automagic check is executed for both automagic check accounts. Quite annoying. 😞
Steeph
