Could someone please talk me through the steps required to set up a bluetooth connection between my Sitecom dongle and my 3650?
I can get the PC to see my phone, but PC Suite refuses to see it, and there are no devices visible in mRouter.
Any help is gratefuly received!
hi,
i will help u.
start bluetooth on the 3650 visible
open mRouter and tick the com4. close it
now open with rightmousebutton over the trayicon near the clock the menu
explore
setup->
services -> bluetooth serial port -> find devices
now it will connect with ur 3650 and now u can start the pc-suite
cya amigappc
😃 Thank you for your help! It is now working!
cool.
now u must only to start the serial port open my bt places -> bt serial port. if u get a prompt start it again. after 10 seconds it will start.
cya amigappc
i'm having similar probs only i'm using the Gigabyte GN-BTD01
i can even transfer stuff from the comp to the phone using the software that came with the dongle but nokia suite doesn't detect connection
the above instructions don't help me
thanks
*edit*
a re-install of nokia suite fixed it all up for me 😃
