Swype for Symbian X6
4 replies · 6,051 views · Started 09 September 2010
If you haven't tried it yet... you should.... very nice.
http://betalabs.nokia.com/
Basically on the X6 though its only working in landscape mode but it certainly speeds things up once you have tried it a couple of times.
Bear in mind it is a beta tho... so there are a few quirks to be expected.
Yes I can definitely recommend it, it took a little getting used to but I would hate to be without it now, also if you do not want to use the swipe feature I prefer the key layout in any case.
it's awesome. as you said, it takes time to learn how to swype correctly, but once you get a hang of it it's tough to go back 😊
