Bomber is a World War I arcade-simulation game. It is played full screen scrolling sidwways. With multiple levels, free form play and lots to explore this should keep you occupied for a while. The program is available from Handango for $10.
Author Notes:
Bomber is a fun World War I arcade-simulation game. It is played in full screen sideway scrolling mode. It is "free" type of arcade game, meaning that you can fly in any direction you want. You finish level after all objectives described in briefing screen are accomplished, but you can accomplish them in any order or by using any means. You can bomb them (hence the title), destroy them with the machine gun, con enemy planes to crash into targets, or, if you are really desperate, go for kamikaze option.
You can get a number of bonuses depending on your type of play. For example, if you chose not to fire a gun (only using bombs), you get bomber bonus. There are 11 such bonuses.
Game features:
-completely modifiable terrain (bombs & planes leave craters)
-parallax (multi layer) scrolling
-precise collision detection
-realistic physics (gravity, objects that fall into water behave realistically, blasts do damage, etc.)
- particle effects (particle explosions, that damage objects, particle smoke, bubbles, etc.)
-high replayability
