newbie = how to remove application from my N7650
8 replies · 4,481 views · Started 25 March 2003
hi newbie :
have installed some application in my N7650... right now i want to delete them... i hightlight the icon .. then press option button... there was no remove function there... also went to tools\app\ can't find the software also...
anyone can guide me to remove the software...tks a million
inside the MANAGER has 2 tabs...
MANAGER = empty
MEMORY = application has 384K but never indicate which application... i think this is the total of all the application i installed.
so how can i remove individual application...?
odd.. on my 3650 it has a list of installed programs (non-java)..
if you want to remove java apps you need to go into APPs but from what i hear you are removing symbian programs.
maybe it might help if u named them?
[quote="ted"]inside the MANAGER has 2 tabs...
MANAGER = empty
so how can i remove individual application...?[/quote]
the only way to remove programs is via App manager in Tools. If there are no entries in manager you have to reinstall programs and when you can see apps in manager, use options to remove application.
enter tools then manager you will see the installed appz. you can delete by using c button or open options then select remove
next time read manual 😊
3ddy wrote:enter tools then manager you will see the installed appz. you can delete by using c button or open options then select remove
How snotty can the people on this page get? And what kind of geek goes and reads the manual for their phone. Even me being an expert PC user can't figure out how to remove some of the blasted Symbian programs from my Nokia 7610 and all you people can do is throw insults at legitimate questions.
BTW, this page comes up 1st on the Google rankings for the following search:
+symbian +Remove applications
God help those who look here.
A smart geek.
The question has been answered more then once in this thread:Go to Tools,App Manager,Remove.
BTW: Your search for "+symbian +Remove applications" is very general.There are different UI's(Series 60,UIQ,Series 80 etc etc) on top of Symbian which are responsible for the simple action of application removal.
