my menu is dead!!!!
all my icons are out of their folder.. because of a damn prog!!!
is there a solution (no reboot plz i wana keep my contacts) to clean the menu and come back to the first one
my menu is dead!!!!
which application? Can you uninstall the application that caused the problem?
Do you have a backup of your phone?
Bob
If all you mean that the icons are not where they used to be (kind of hard to figure out from the problem description) then you can move them around where ever you want (put in any order or any folder).
I had the same problem when I uninstalled Space Doubler trial. It's still the same with the full version to, remove it and it messes up your icons. Once this happens you literally need to go to options with the left function key and "move" each icon back into its right folder, or however you want them even. From there you can then arrange them within their folders to how you like them again.
When this happened I was lucky to have access to the girlfriends 7650 so knew easily where everything went.
Obviously failing that a hard reset, which gets rid of your contacts but not GPRS Email settings I've found.
Ian
This also happoned to me when I uninstalled eprofilePro
i had to move all my icons 😞
thx sdoubler
