N8 and Accuweather
30 replies · 21,978 views · Started 12 October 2010
My ever growing feeling of de ja vu with the N8 has been increased with its inability to either display my Current location, although Ovi Maps 3.06 has me spot on. It starts by saying..."Getting position" and then to "Loading..." and there it stays ad infinitum.
I therefore try Add location and type in the county city, "Gloucester", which on the N97 generated 4/5 possible locations (including the US) but the app just says "Searching..." and stays that way.
It's ironic really as I had no problems with Accuweather on the N97.
Is anyone else experiencing this on the N8?
ironass wrote:Just you both be careful what you wish for...
after the N97 'experience' this is a concern. Have you had problems with crashing? does the GPS work well?
thank god it doesn't have a camera lens cover.......
spirit44 wrote:after the N97 'experience' this is a concern. Have you had problems with crashing? does the GPS work well?
No crashes so far.
GPS is spot on and quick.
It wasn't so long ago that I remember the N95 8GB being berated for not having a camera lens cover.
My... how times change! 😃
kontraband wrote:yeah, Ive got one :tongue: although a little less :tongue: atm and more 😡
Glad I'm not the only one!!! 😡
I think you'd better tell Rafe to reserve a large chunk of the server for the N8 forum. 😃
I never managed to get accuweather to work well on my n97, all other gps things work spot on.
It seems to me that accuweather gives up trying to get a gps fix to quickly, i don't know if the developers could make it search for longer but thats what my n97 needs cos if i have ovi maps running in the background accuweather will get a fix instantly.
theblob wrote:I never managed to get accuweather to work well on my n97, all other gps things work spot on.
I had difficulties getting Accuweather to work well my my N97 as well. I never managed to get the GPS fix to work at all. I just pick my city (Vancouver) and set it as the default.
Update
For some strange reason, Accuweather has decided to work and I'm happy to report that it is now showing my, "Current location".
I wish I could tell you that it was something I'd done... but I can't.
It was just working this morning.
As for the N97, the only way I could get my "Current location" on it was to install Maps Booster from the Ovi Store and that solved the problem.
Before purchasing it you could try installing Ovi Maps v3.06 to see if that helps with positioning, if you haven't already got it.
I'm using accuweather with no problems on getting location. except i have my gps keep popping on and off (widgets in offline mode), just removed accuweather from the widgets.. lets see how it goes.
Ya i have also got the same concern. Somebody please help me out. Trying to wait patiently, but really wish someone will get with the solution. I have tried to get the resolution through many sources, but still can't get through.
So friends please suggest ...
The accuweather home screen widget seems to need a constant connection to be able to update automatically. Does anyone experience this? Is it the usual behaviour? Is there anything better for the N8?
So far loving the N8!😃
Thanks in advance!
I have accuweather, and have a constant 3g connection, yet accuweather does not update on its own, and there no refresh settings.
I have to manually update it..
thank sucks
I don't know why it wont update on its own.
hi all....i think i have found a solution for this problem. I was having the same issue with my n8 with accuweather. but the configuration of accuweather is not same as it was in n97/n97 mini. accuweather is a widget for n8 and you can add it to the home screen as well. so before opening the application you need to go online mode for the widgets from the home screens. then open the application and it works like a charm.
Is there a good alternative to Accuweather for S^3? I'm interested in it showing me a SPECIFIC place (not my current location), and optionally letting me scroll to additional locations.
src81 wrote:hi all....i think i have found a solution for this problem. I was having the same issue with my n8 with accuweather. but the configuration of accuweather is not same as it was in n97/n97 mini. accuweather is a widget for n8 and you can add it to the home screen as well. so before opening the application you need to go online mode for the widgets from the home screens. then open the application and it works like a charm.
Errr... AccuWeather is a homescreen widget on the N97. 😃
phessler wrote:Is there a good alternative to Accuweather for S^3? I'm interested in it showing me a SPECIFIC place (not my current location), and optionally letting me scroll to additional locations.
AccuWeather > Add New Location allows you to select specific locations, other than Current Location.
You can add as many as you wish.
Also saves having to get a GPS lock for Current Location.
ironass wrote:AccuWeather > Add New Location allows you to select specific locations, other than Current Location.
I tried that. But it *always* switched back to "Current Location", and didn't cache the weather results as long as I would like.
ironass wrote:Errr... AccuWeather is a homescreen widget on the N97. 😃
i had a n97 mini and there accuweather worked even without going online for home screen widgets.
my accuweather widget for my N8 now is updating, but its always switching from my preset home location to "Current Location" , and kicking off the GPS for location info.
I don't want it using Current Location because it drains the battery more having to use GPS all day..
I have no idea why it started behaving like this.. its such a buggy app
Using accuweather and it is such a buggy fristrating app! hopefully alternatives will start coming out soon!
Can't believe it's the only weather widget out there! Weather is usually the first thing people with widget phones add so you should expect loads.
Anyway restored my phone yesterday (videos wasnt working properly) accuweather was one of the first things I installed and so far, it's behaved itself! *fingers crossed*
Otherwise, loving the N8!! Best phone out there at the moment IMHO
I'm having a big issue with Accuweather widget, cause the widget is not showing the RealFeel temperature that the inside App and Accuweather are really displaying but a random number :S
I found it to be buggy on my N97, N97 mini and on my N8... Also have notice significant battery drain having it installed on my N8 so I've just removed it.
slashd0t wrote:I found it to be buggy on my N97, N97 mini and on my N8... Also have notice significant battery drain having it installed on my N8 so I've just removed it.
Did you have your location fixed or let the app to find your location by GPS?
