Does anyone know if the bluetooth dongle works on windows XP without service pack 1? Everytime I try to connect it gives me an error report.
Thanx
Thanx
have you tried searching the forum? for sho there's some archived topic similar like this 😃
Also if you specify which dongle you are using those with the same setup may be able to assist.
Bob 😃
For ANY Bluetooth device to work with Windows XP you need Service Pack 1.
Hmm I dont have it and its working fine ta! MSI BT dongle
I've got WinXP installed and I recently bought a Conceptronic USB Bluetooth adapter and after some problems through the configuration process everything works fine.
Well, not everything, I can't send files directly from my phone to the PC. I've to put them in C:\Nokia\images and the upload them with PC Suite.
Does anyone has the same problem?
