Anybody know if there is a way to connect P800 to a printer and make it print any camera-made pictures?
Printing with P800
you can use a BT printer, it works!! 😉
is there a software that I would need to install to allow prinitng with bluetooth/IR enabled printers?
My nokia 9110 was able to do IR printing to HP Lasers that had IR.
Wonder if the P800 supports this as well
P800 works fine, all you have to do is to send the image throug BT if it is a BT printer or IR if it is an IR printer, it works 😃
Can anyone suggest a bluetooth printer adapter then? Does this plug in directly to the printer port?
