can anyone help me? these days, i keep getting a message saying phone memory low. In fact, my images, my smses, my videos are all set to be stored in the mmc card. and still , my phone memory still decreasing. Is there anyway to stop this from happening? without sufficient phone memory, i cannot install anything at all.... sigh...
how do i set my contacts to be saved only in the mmc card and not the phoen memory? i have checked the TOOL > MANAGER > PHONE MEMORY and it says about 800kb are used in the calendar application. i didnt even store any appointment or watever dates in it... why does it say 800kb has been used by the calendar?
pls pls help me..... please !!!
Anyone have a solution for this?
After searching the forums for a while I've figured out how to move my messages, but found nothing on contacts / calendar.
Would be pretty useful 😊
phone memory is the default of the contact and there is no way (as of now) that you can use the mmc as it's default memory. if you're saying that you only have fiew files stored in your mmc and phone still prompts you memory full, try these steps:
- back-up all your data to your pc.
- do the hard reset on the phone, (be sure that you have ample supply of battery once you do this), by pressing *#7370#
- restore your data back to your phone.
if after this, you still experience such things, then it would be better to bring your phone to the ASC and have it be diagnose.
Thanks for that - I don't have any problem as such, I'm just trying to free up as much of the phone memory as possible.
Wasn't sure if you could move the contacts / calendar memory over or not, but I guess I can wait for a version of FW where you can 😊
